It is currently Mon Oct 20, 2014 5:47 pm
 Page 1 of 1 [ 4 posts ]
Author Message
 Post subject: Exile Crack
PostPosted: Sat Jul 01, 2006 11:42 am
Whilst looking to see if I had any notes about Firebird tape stream loaders, I found an Exile deprotector I'd written a few years ago. With a little bit of tweaking I got it to work with the version at Acornpreservation.org
http://www.acornpreservation.org/archiv ... l%2040-80T)/Exile%20(Superior)%20(B)%20(Disc)%20(Dual%2040-80T)%20%5BFDI%5D.zip
I guess it shows that once the spade work is done, to bypass the protection is quite simple...
Seems like it's a different version to that in the archives, since the files are different lengths + execute addresses. Unfortunately, since B-Em doesn't seem to allow me to save files to disk, I can't test if it works :P
10*LOAD !BOOT
[Breaks loop]
20?&1F28=&60
[Create loop in BASIC]
30REPEAT
40CALL&1F10
[Sidestep self EORing loop]
50IF ?&1F13=&28 THEN ?&1F28=&C9:?&1F2A=&60
60IF ?&1F13=&29 THEN ?&1F28=&60:?&1F2A=&D0
70UNTIL ?&1F13=0
[Change JMP&7800 to JMP&1B00]
80?&1FDC=&4C : ?&1FDD=0 : ?&1FDE=&1B
90P%=&1B00
[Change CH (of CH."!B") to LO
100[LDA#&4C : STA&789B : LDA#&4F : STA&789C: JMP&7800
110]
[Continue as normal]
120CALL&1F2C
This will drop you to the BASIC prompt with !B loaded.
Typing 120 will delete 120 which performs *RUN EXILEL.
RUNning the program will load EXILE (the picture) and sort out the video.
Next, all that is required is a memory editor to view the "virtual" catalogue information at E00 (filenames) and F00 (file information).
There's a custom filesystem in place, so files can only be *LOADed and *SAVEd, *COPY won't work!
Offline
 Profile
 Post subject:
PostPosted: Sat Jul 01, 2006 3:54 pm
Erm, what's stopping it? I can save to disc absolutely fine. Unless you're doing something daft like saving to an FDI.
Offline
 Profile
 Post subject:
PostPosted: Sat Jul 01, 2006 5:08 pm
I can save to disc without any problems... but then I replace disc 0/2 with the FDI, load another file off it, return to my other disc where I'd previously saved the file (EXILE.SSD) and it's not got the file I'd just saved on it.
The file's date modified hasn't altered either.
I've tried using Model B and Model B+ 1770.
Loading any disc in Drive 1/3 gives me an empty disc with 00 files of 31 on 00 tracks.
Offline
 Profile
 Post subject:
PostPosted: Sat Jul 01, 2006 10:30 pm
Just found the problem. A quick workaround seems to be to either quit the emulator after writing to disc (somewhat impractical) or to run the emulator fullscreen.
Offline
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
phpBB skin developed by: John Olson
Powered by phpBB® Forum Software © phpBB Group
