Hi Folks,
It's been awhile and here finally is a new BeebSID disk - Queen - one of my favourites!
beebsid8b.jpg [60.14 KiB]
Downloaded 565 times
beebsid8.zip [49.16 KiB]
Downloaded 113 times
Controls:
A-O - pick a song
TAB - switch between Play All / Play one song.
Spacebar - Pause
Return - unpause
There's not a bad collection of disks now - I made a summary page of all ten disks here:
http://www.pitfalljones.com/bbc-sidquiz/sid_programs.htmI finally figured out how to fixup Sids that had zero play addresses and do the relocation more successfully as well.
I discovered quite a few Sids assume there is other C64 hardware available that the BBC won't have - timers for instance at $DCxx and $DDxx.
They normally have 'RSID' in the header instead of 'PSID'.
Some will also use memory outside of their load range in areas like $2C0 and that has to be relocated as well.
Tricky stuff!
Anyway I'm glad I've finally cracked this one - I started it last year would you believe!
- PJ
