30th Anniversary BBC and Electron Collection
Michael Brown
Re: 30th Anniversary BBC and Electron Collection
Postby Michael Brown » Mon Feb 20, 2017 5:49 pm
Hi Sydney,
ref Hyper Sports...
I have a suspicion that this is another DFS under emulation problem - like E-Type, Repton Infinity and Clogger and may need the 1770 DFS or Watford DFS selecting in order to correctly load all their files.
If someone could let us know.
Mick.
Last edited by Michael Brown on Mon Apr 30, 2018 4:00 pm, edited 4 times in total.
Michael Brown
Postby Michael Brown » Fri Feb 24, 2017 1:38 pm
:lol: Post removed
Last edited by Michael Brown on Sat Apr 28, 2018 12:48 pm, edited 1 time in total.
Michael Brown
Postby Michael Brown » Fri Feb 24, 2017 1:39 pm
:lol: Post removed
Michael Brown
Postby Michael Brown » Fri Mar 03, 2017 12:18 pm
:P Post removed
Michael Brown
Postby Michael Brown » Fri Mar 10, 2017 12:58 pm
:oops: Post removed
Last edited by Michael Brown on Sat Apr 28, 2018 12:49 pm, edited 1 time in total.
Postby sweh » Fri Mar 10, 2017 9:12 pm
Not sure if you saw this cross-thread, but I wrote a program that looked at all the game titles and spotted some duplicates (based on the DSD's leenew sent me)
Sea Wolf (Disc051) already exists on Disc018
Duck! (Disc058) already exists on Disc026
Reversi (Disc082) already exists on Disc076
Darts (Disc087) already exists on Disc057
Adventure (Disc095) already exists on Disc092
Robin Of Sherwood (Disc100) already exists on Disc055
Battleships (Disc113) already exists on Disc082
Lunar Run (Disc114) already exists on Disc113
Fruity (Disc114) already exists on Disc107
Napoleon (Disc115) already exists on Disc114
Unsure if these are real duplicates or not. Napoleon and Lunar Run generate identical SSDs when using my split-program.
Michael Brown
Postby Michael Brown » Sat Mar 11, 2017 10:19 am
Hi Sweh,
All the above games are simply same title but different game except...
These 2 were simply placeholders on discs I was creating and sent to Lee.
I had to change some titles around as I discovered I had already got them under different names and software companies - The games taken off discs 113 and 114 will be available via Alternative disc 010 in a few weeks.
Regards,
Mick.
Last edited by Michael Brown on Sat Apr 28, 2018 12:53 pm, edited 1 time in total.
Postby sweh » Sat Mar 11, 2017 12:24 pm
Michael Brown wrote:PS If in NYC - have you tried a platter at Tony's W 43rd st ?
I tend to avoid the Times Square area as much as possible; it's too full of tourists.
Michael Brown
Postby Michael Brown » Sat Mar 11, 2017 1:38 pm
:P Post removed
Last edited by Michael Brown on Sat Apr 28, 2018 12:54 pm, edited 1 time in total.
Postby sweh » Sun Mar 12, 2017 2:11 am
Oh, I don't have any problems; was wasn't expecting those results and so asked about them ;-) If you say they're good then that's fine by me :-)
Another question, though; the title for disc 112 is "D*.C 112" - is that correct?
Michael Brown
Postby Michael Brown » Sun Mar 12, 2017 9:18 am
Hi Sweh,
My copies of disc 112 currently seem OK - where did you get yours from?
regards,
Mick.
leenew
Postby leenew » Sun Mar 12, 2017 10:07 am
Err... that would be me :D
I will check mine tonight... :-
Lee.
Michael Brown
Postby Michael Brown » Fri Mar 17, 2017 1:30 pm
:lol: Post removed
Last edited by Michael Brown on Sat Apr 28, 2018 12:55 pm, edited 1 time in total.
Michael Brown
Postby Michael Brown » Fri Mar 24, 2017 1:47 pm
:roll: Post removed
Michael Brown
Postby Michael Brown » Tue Mar 28, 2017 4:34 pm
:lol: Post removed
Last edited by Michael Brown on Sun Apr 29, 2018 6:48 am, edited 2 times in total.
Michael Brown
Postby Michael Brown » Fri Mar 31, 2017 10:15 am
:) Post removed
Michael Brown
Postby Michael Brown » Sun Apr 09, 2017 7:12 am
:roll: Post removed
Last edited by Michael Brown on Sun Apr 29, 2018 6:50 am, edited 2 times in total.
Michael Brown
Postby Michael Brown » Sun Apr 09, 2017 7:32 am
:oops: Post removed
Michael Brown
Postby Michael Brown » Wed Apr 12, 2017 2:01 pm
:lol: Post removed
Michael Brown
Postby Michael Brown » Thu Apr 13, 2017 12:06 pm
Created in April 2017... here is Games Disc 114.
Disc114.zip
(141.38 KiB) Downloaded 58 times
The disc is called Disc114.dsd so it can be loaded into a Datacentre on a real BBC without having to rename it.
The 18 games on this disc include...
Trawler by S. R. Whiting.
Death Zone by Tom Lindberg.
Gotta Go Home from Viking Software.
Miss Fortune And The Seven Keys by Adrian Smith.
Bridge To The East from Ixion Software.
Break-Out (Classic Arcade Games) from Ganymede Systems Ltd.
Downhill Skier by S. W. Thomas.
Sailplane! from Pavilion Software.
Amazing by James Bridson.
Ploy from The Micro User (3.12).
Napoleon from Molimerx Limited.
Time Lords from Red Shift Ltd.
Diamond Trial (E) from Electron Computing (#3).
War Games (Tobruk and Salamanca) by C. T. McGurk.
Jolly Jake's Escape from Arrowsoft.
Five In A Row by Michael Bawtree.
Hypersmash by James Farmer.
Fruity from Odyssey.
NOTE: Death Zone allows you to save your score/position to disc.
Also, due to a minor graphics fault with BeebEm 4.14, Gotta Go Home does not work properly. However, it has been modified to detect BeebEm and patch the problem. It works normally with B-em and on a real BBC. You can also save your score/position to disc.
Lastly, Bridge To The East resets the disc drive (so requires *DTRAP on a real BBC with a Datacentre fitted).
EASTER EGGS: If you press ESCAPE during some of the loaders and instructions, then you can skip to loading the game... This works on Napoleon and Time Lords.
All original filenames have been kept where possible, but some have been changed where they conflict with the limitations of the Disc Filing System. Copy protection routines have been removed.
This disc has also been checked for *KEY related issues and is OK.
Regards,
Mick.
Last edited by Michael Brown on Mon May 21, 2018 4:38 pm, edited 14 times in total.
Michael Brown
Postby Michael Brown » Sun Apr 16, 2017 8:37 am
:lol: Post removed
Michael Brown
Postby Michael Brown » Fri Apr 21, 2017 9:33 am
:lol: Post removed
Michael Brown
Postby Michael Brown » Sun Apr 23, 2017 6:40 am
:lol: Post removed
Michael Brown
Postby Michael Brown » Fri Apr 28, 2017 2:02 pm
:lol: Post removed
Michael Brown
Postby Michael Brown » Tue May 02, 2017 12:07 pm
:lol: Post removed
Michael Brown
Postby Michael Brown » Sat May 06, 2017 11:18 am
:D Post removed
Michael Brown
Postby Michael Brown » Fri Jun 09, 2017 3:42 pm
:lol: Post removed
Michael Brown
Postby Michael Brown » Fri Jun 09, 2017 3:57 pm
:lol: Post removed
Michael Brown
Postby Michael Brown » Fri Jun 09, 2017 4:34 pm
:) Post removed
Michael Brown
Postby Michael Brown » Mon Jun 26, 2017 4:11 pm
:) Post removed
