Amstrad CPC noisy tape player
Postby danielj » Sat Jan 06, 2018 7:23 am
So, I've just got the tape player in my CPC 464 back up and running after having burnt out the old motor and inductor (don't ask), and when the motor's running the speaker is generating a horrible buzzing noise. It's loading fine, so that rules out great swathes of the circuit, and the CPC's sound is also fine (that's amplified through the tape deck), so that rules out a load more I'd have thought. It's just when the motor's running.
I've replaced C322/C324, but it's still buzzing away... Any ideas? I'm thinking C304... Or is it not likely to be one of the caps?
Re: Amstrad CPC noisy tape player
Postby daveejhitchins » Sat Jan 06, 2018 7:36 am
Have you replaced C323? - It's the one directly across the motor.
Postby danielj » Sat Jan 06, 2018 7:45 am
That'd be sensible - it's ceramic so I just assumed it was probably OK...
Postby danielj » Sat Jan 06, 2018 9:20 am
Nope :( that didn't fix it...
Postby daveejhitchins » Sat Jan 06, 2018 11:08 am
C304/C315/C318/R306/R313 - Supply line decoupling - these work with L301 so they all need looking at.
Or - is it just a really noisy motor?
Postby danielj » Sun Jan 07, 2018 5:09 pm
Just to follow up on this - I haven't changed those other caps, but it seems to have shut up now. Perhaps it was just a grubby motor and now it's been used a bit has calmed down!
Postby daveejhitchins » Sun Jan 07, 2018 5:17 pm
danielj wrote:Just to follow up on this - I haven't changed those other caps, but it seems to have shut up now. Perhaps it was just a grubby motor and now it's been used a bit has calmed down!
Or the electrolytics have re-formed a bit!
Postby danielj » Sun Jan 07, 2018 5:19 pm
Can that happen? :O
Postby daveejhitchins » Mon Jan 08, 2018 5:26 pm
danielj wrote:Can that happen? :O
It can and does.
There was an article explaining it, back in the mid 80's (I was working for Rank Hi-Fi, at the time, and had the job of improving reliability of the Leak 2000 series). What was noticed was that as capacitors 'aged', when not powered-up, was shrinkage. This separated, slightly, the internal winding of the capacitor - so reducing the capacitance. When powered-up again, the shrinkage was reversed thereby restoring the most of the lost capacitance. There were other factors involved too, however, the shrinkage was the main one.
Return to “other vintage computer hardware, software and games”
