MMBExplorer released!
Re: MMBExplorer released!
Post by lurkio »
robcfg wrote:
Thu May 27, 2021 9:56 pm
Can you provide me with some more details, like which platform are you running it on and how do you take off the SD card? Edit: Can you try to reproduce the same steps, but closing MMBExplorer before taking out the SD card from the computer?
Running MMBExplorer on macOS Mojave. I think I did close MMBExplorer before ejecting the card from the laptop, but I can't be 100% sure. I eject the card by using the macOS "Eject" menu item. Then I physically remove the card from the slot in the laptop.
I'll try and come up with a series of steps and a specific BEEB.MMB file that reproduce the error but I suspect it'll be tricky because the error is intermittent. In fact, I'd say it was rare. (But it's fairly catastrophic when it happens!)
Orac
Post by Orac »
I've just come across this little gem of an app, thank you very much for it.
I don't know if its already been requested, but a nice option would be to export the directory contents to a csv file.
John Spink
robcfg
Post by robcfg »
Orac wrote:
Sat Jul 24, 2021 12:45 pm
John Spink
Hi John,
Thank you for your kind words!
I definitely could do it, is the current order (Locked flag, Directory.name, size, load address, exec address and crc32) about right for your needs?
Rob
robcfg
Post by robcfg »
As I said, it wasn't difficult at all :mrgreen:
I'm going to fix a couple of small details before making a new release, which should be coming this week.
Meanwhile, here's a csv file that I just generated.
Rob
XOR_Data.csv
(1.01 KiB) Downloaded 25 times
Orac
Post by Orac »
Wow, thanks Rob,
The column order looks fine to me.
Regards,
John
robcfg
Post by robcfg »
Nice!
I'll sort a couple of things out, and shout here when the new release is ready.
robcfg
Post by robcfg »
The time has come!
Here's a shiny new release, v1.2.8, which includes Orac's request to export the disk directory as a CSV file, and also implemented some changes in order to avoid the problem that Lurkio reported.
Please grab it here: https://github.com/robcfg/retrotools/re ... tag/v1.2.8
And report any bugs you may find.
Rob
shifters74
Post by shifters74 »
does MMBExplorer support the extended BEEB.MMB files that can be used with MMFS 1.50 or greater?
shifters
robcfg
Post by robcfg »
Not yet.
I started working on it, but life got in my way...
I'll move it upper on my priority list.
