Odd "Syntax error"
julie_m
Odd "Syntax error"
Post by julie_m »
A couple of times now I've called a buggy machine code subroutine and it has returned to BASIC with 'Syntax error'.
The only thing I can see that might have been responsible is a STA 0,X which I guess could have stomped on some zero-page variable used by BASIC, if X was wrong, and messed up the interpretator state; either by setting an error flag or by altering the "next byte of program" pointer and causing it to read nonsense.
Does that sound likely? I can't seem to reproduce it .....
Bobbi
Re: Odd "Syntax error"
Post by Bobbi »
If you leave the stack imbalanced it will often result in spurious BASIC errors.
gfoot
Post by gfoot »
Like "OSCLIOSCLIBPUT#PLOTMID$(WIDTH at line 830"!
julie_m
Post by julie_m »
I've had the OSCLIOSCLIOSCLI stuff before, and modified my editing technique to avoid it.
Anyway, I've managed to reproduce the fault. Writing &00 to location &0C causes 'Syntax error'!
I'll find a BASIC IV disassembly and see what that address does.
Return to “programming”
